what compressor for a hvlp gun
Air Displacement12.6cfmMaximum Free Air Delivery9.2cfm
don't know what free air means but
i think it will do for what you are after
will increase in price alot tho
gonna keep posting this so i dont have to hunt for it
gun
Air Consumption : ................................ 9.5 CFM
Air Inlet Connector : ............................. ¼”BSP
Operating Pressure : ............................ 20 - 43 PSI
your current compressor will do what again?
we could combine 2? or don't you have the space?
i think connecting 2 tanks together with compressors will give plenty
could be interesting
well think about it
2 X 5cfm surley would equal 10cfm?
dont know much about it but its somthing to look into
i have done no work on such thoughts
pressures may need to match to prevent tanks overcharging so wiring it up with a relay may help on lower machine to turn on higer pressure
try to find some info on it dave if you dont report back i will look at 11pm tonight
Find the highest possible CFM rating that your HVLP paint gun will be running on (this can normally be found in the owner's manual as well). Multiply the highest CFM rating by 50 percent. Add this number to the total CFM required. The number you come up with will be the highest rating of air compressor you should be looking for, as CFM ratings within 15 percent of this number will allow you to run your tools without over-taxing the compressor.
:spin:
simple
round it up to 12 the gun
18cfm
between 16 and 20 ish
seems high to me
9.5 is obviously the bear minimum you want to be able to charge the tank quickly
with dodgy use
just to rub it in dave
at work we have one of these
http://www.kmtservices.co.uk/for_sale/compressor.html
tank size is massive as well
are you sure you need a compressor and not an air pump?
our spray gun at work as posted http://i88.photobucket.com/albums/k175/daz_rich/a%20day%20in%20the%20life%20of/DSC03005.jpg
not found some what does 20 psi tho
