Technical  What am i missing?
Neojames2k
United Kingdom.
Hey guys,
I've just bought a 1372cc turbo engine which was previously fitted to an x1/9. It's going back into another x1/9 so fitment is not really an issue.
Problem is, being a second hand motor I fear I am missing some parts which I need. I've taken pictures of what I have (attached) but I'm wondering if you guys would be able to fill in the blanks.
From what i can see I am missing:-
Turbo actuator
Fuel Rail
Injectors
Injection Wiring Loom
Neojames2k
Others will proberly be able to help as i am not to clued up on x1/9's, but i am pretty sure you are missing the injection ecu aswell.
Thanks Dude,
It's more UT advice that I'm after than X1/9 as all the engine bits are from the UT.
Have you got any piccys of the injection ecu so I know what I'm looking for when I dive into this guys parts bin
After much searching around I found a copy of the uno haynes manual which I had laying around.
For future reference of anyone who stumbles across this thread the MK2 ECU is on top the air flow meter
Looks like I am missing the parts I first assumed and also that someone has decided to chop the ignition loom up a little to make it work. Ah well, just means a lil more head scratching over a wiring diagram to work out what's been done
