What A Joker
What A Joker
Apparently its a factory fault! God Ive just passed that mark! hope mine doesnt go!!! Its hardly the best way to sell your car stating it comes with factory faults!
Paul Maks
Christ better get my 71k bravo back for its box swap! It must have gone 6k ago!
i was gonna say tom i`m on 80k original gearbox is fine no probs at all, i think it depends on the hand that crunches the gears,
Pete
hmm well i watched fast and furious again the other day. and this morning i was trying to double clutch it through the gear. after crunching my way from 1st to 5th back to 3rd with out crunching and then crunching back to 5th i thought sod this. just keep it planted and then shift extra quick. BAD MISTAKE. missed the gear and just reved liek a nob doing 70 on dual carrage way :( i learnt my lesson
Smee
Not sure, but arent you only supposed to double declutch on your way DOWN the gears? That way you can match the revs better to the lower gear
YEP:) :) :)
To perform a double declutch, the clutch is pressed and the gearbox shifted into neutral gear. The clutch is released, the throttle is "blipped" which applies power to the disengaged gearbox, thus speeding it up internally. The clutch is pressed for the second time and the gear lever moved (smoothly) to the desired gear. The clutch is released again, and the drive continues. This operation is suitable for a down change. For an upchange, it is usually sufficient to allow the gear lever to rest momentarily in neutral and no "blip" is applied. The whole thing can, with practice, take no more than a fraction of a second, and the result is a very smooth (and satisfying) gearchange.
Blipping the throttle to the precisely matched rpm is no doubt an acquired skill, but if done properly it affords a silky smooth downshift. One might argue that this technique is not needed on a modern synchronized street car in the everyday driving. Yes and no.
A case in point: you are in 4th doing 70mph on ice or on packed snow. Suddenly, you need to stop the car in emergency (a fruitcake in an automatic SUV thinks that she's invincible and plants herself solid into a snow bank, blocking the road with her ugly bath tub on wheels. I see this happen every winter). If you hit the brakes, you're history. You need to drop 2 gears and then brake with the engine. The trouble is, at 70mph the gearbox ain't gonna let you engage 2nd no matter how hard you pull that stick. OTOH, you can do it easily if you know how to double declutch properly. This technique has saved my butt more times than I care to admit. I habitually double declutch at all times in any weather and although I would be first to admit that this is not always called for, this habit of mine is probably the only reason why I have never had a single gearbox breakdown on any of my cars. Ever. One more tip: always depress the clutch fully to the floor, enabling a complete disengagement. This saves your disk/basket.
Not only me that went on to the encyclopedia website then eh Patrick :)
Thought I'd ask the question
I thought I'd ask the seller where he got his info from about the gearbox:
Dear evanreecewalker,
Sorry to ask, but where did you get the info that all Bravo gearboxes go at 65000 miles and that it was a factory fault? I am getting concerned as mine has done 72000 and is a 155HGT Thanks
His reply:
yeah sure, when my gearbox went i took it to two gearbox specialist who both
said that and then i went in to my local fiat dealer where they confirmed it
there! it cost me just over 600 to fix but at least i know it wont go again.
Thanks evan
Re: Thought I'd ask the question
well at least has a genuine reason to think that,
Smee
You should have asked what he did to uprate it and why it "won't go again".
69,000 and counting.
In what way would you 'uprate' it?
No idea myself Tom - his words not mine.
Obviously he purchased a titanium gearbox.
What a knobcrust.
Another thing to add to my prayer list..."please don't let my gear box go before i win the lottery!". 92,000 miles and counting....how much would you expect to pay for a new gear box (a normal one!)?
just got this reply.
A gearbox specialist uprated the diff as this is what came free and smashed
the bottom out of the casing. cost me just over 600 with fitting cost.
thanks, evan
so now he's saying that it's not the gearbox that goes it's the diff.
re
to be fair, i think me and ribzz had same problem that the diff pin came loose, first of all broke the speedo sensor, so lost our speedo's then about a week later i had a big baand and it had knocked a whole through my casing wher ethe speedo sensor was!
i might be wrong about ribzz, but i think at the time there was about 4/5 of us with the same problem, and mine was at about 70k
and i know he definately had to replace his gearbox!
K
2
1K
Dark Lurker
T
4
738
Insomnia
I
M
1
820
Dark Lurker
C
2
426
Robin
R
