Advice please. X reg jtd multipla, will not start.
Have studied all I can find on the forum but a bit stuck now with how to proceed.
We are on an outer island in Orkney, no fiat dealer for 150 miles. Might manage to borrow a ODB2 reader but at this age it may not tell us much. Experienced with pre electronics etc diesels.
Car history is:
Last 10,000 miles on our own quality biodiesel. A very useful and much loved car.
Injector symbol for some time, low power (EGR or throttle pot/ connections perhaps) but useable then laid up for a year with a broken sump. Repaired with Isopon. Started OK after repair. Used for a week, always started but sometimes slow to start. No misfire on starting, no smoke, behaved like it was having to pump fuel through. Once running, ran as usual, low on total power but no misfire and perfectly useable. never failed after starting.
Now will not start at all.
Wondering if the high pressure pump has been doing the sucking from the tank?
I assume there is a tank pump? Should I be able to find a resettable cut off valve? (referred to in some posts) If so where? How do I check if the tank pump is delivering to the high pressure pump?
More advice and suggestions please. Thanks in advance
Car history is:
