Technical  weird front windows help
alanandalan
Hi everyone, looking for some advise, i have a 1.2 2002 Stilo, 5 door. The problem is, i replaced the o/s/f knackered window regulator, and the window went up and down a treat, i then read in the handbook, you can open or close the front windows via the ignition key, i thought cool i will give it a try. shure enough the front windows did go down, but the passanger one only half way, and the drivers all the way down, ok so try the trick to close them useing the key, nope nothing worked, bugger got the windows stuck open:bang:
and would not even go up using the window switch. So locked and unlocked the car, and able to close the windows on the switch, also ocasionally useing the switch in door panel the window will go all the way down but will not come back up again, you have to lock/ unlock the car. Has anybody else had the same problem.possible causes, window control module pooped, the key operation needs synchronising, or adjustbthe settings in the main ecu ?? any thoughts appricieated Thanks Alan
you may have to either clean the switch on the door handle, clean the anti trap sensors in the door frame(for the windows) or remove the door card and give the motor a clean, but my moneys on the anti trap sensors....
