I'm going to pick up two 50kg stone lions this weekend in my Panda 1.2, how should I distribute the weight across my car, I'll be going alone so the boot/backseat and passenger seat are all open.
Put them as close to the centre of the car as possible. If you can put them on the rear seats and strap them in SAFELY without damaging the seats then do so but don't do it if you're at all worried about them coming loose because the last thing you want in the event of a crash is a 50kg lion hitting you in the back!!!!!!I'm going to pick up two 50kg stone lions this weekend in my Panda 1.2, how should I distribute the weight across my car, I'll be going alone so the boot/backseat and passenger seat are all open.
Like I said, if you have a crash and they move around and hit you you're a gonner......They are 23" tall each, do you think it's worth standing them up in the boot as they are stood up,surround them with pillows and cushions, or would 100kg in the boot be a bit of a drag?
Personally I'd put them in the boot and take lots of pillows and blankets to support them because you don't want them moving around in the boot either.......
Ditto, hence why I said only do it you can be completely sure they won't come loose. To me the risk is not one worth taking if it's at all possible they could come loose.I don't see putting these stone lions in seat belts as at all safe.
They will bounce around on the seat and could extricate themselves from the belts.
Unlike a person, they don't have legs on the seat cushion and hanging down. Hence their weight distribution on the seat is all wrong for the seat belt and in a collision they could fly over the top of the belt.
I would never consider loading them any where other than lying flat in the load area.
