Thomas, you're correct, it is a thick nylon washer and squarish in section.
I meant to say the washer is quite thick and a hard plastic type material and relatively square in section....this annoying phone types it's own words for me.![]()
Hi, new here, have a weber 26 IMB 10 and want to fit on a ford sidevalve, I've been told it's a much better carb than the standard zenith or solex but needs rejetting to suit the 1172cc engine. Anyone know where I can get spares and jets. As a matter of interest, what is the HP of the fiat 500,
I spoke to a guy at euro carb today and he didn't seem to know much. He only had information specific to model. He did say the technical guy wasn't in today, so when I get the carb I will order a service kit to start and talk to the tech guy.
Now you tell me, just kidding, I thought that too after I bought a 26. Hadn't looked into it, usual way I go at things. Original carb is 25mm even on a 100e inlet manifold that is 28mm, so yes 28 may well be a better way to do it. What capacity is the 126
You are aware that I'm putting the carb on a ford sidevalve 1172cc.126 capacity is 650cc. There are very few adjustments that you can make on the carb and I am thinking that with a standard carb you will get a standard mixture but with an increased volume flow.
I read there is a 126 Abarth, I assume that will use a bigger main jet
Yes to the first question and there is no such thing as an Abarth 126 so no idea where you read that. Why do you assume that you need a bigger jet?
Just that the engine is twice the capacity, I guess I assume wrong.
Maybe I saw the 500 Abarth, be gentle it's old age setting in.
Wow, sounds like you've been through it then, I'm very fortunate to have been healthy all my life, just the odd thing or two but nothing as serious.
I guess I'll fit the 26 and see how that works first.
