Technical  Water on drivers floor.
Chevyboy70
Twice now found heavy moisture on drivers floor. A/C maybe?
Model
Fiat 500 pop
Year
2012
Mileage
45344
See if it smells sweet and looks like engine coolant, especially if coolant level drops.
Air con water that usually drains outside/underneath the car is usually clear with no smell (unless dangerous bacteria from poorly serviced)
Does it happen after heavy rain etc?
I had a customer several years ago complaining about damp on passenger floor which smelt, there was no coolant loss or other external signs, one day she brought the car in and I had it up on the ramp for another issue, I happened to open the passenger door and saw her two Show dogs were using the floor as their toilet, after pointing this out to her there were no further complaints.;)
Had A/C line cleared, still wet. Removed cowling and cleaned cups, still wet. Cleared door channels, water goes out where its supposed. Found a company who exclusively finds leaks. When I find out, I will say so here.
EVen water specialist not able to find water coming in under mat on drivers side. It does not have to be raining
