General  Water leak
General  Water leak
4567
I have recently purchased a 2006 fiat doblo high top, find now that there is a leak on the passenger side at the seam on the parcel shelf, and is dripping down onto the side window switch. took it back to the dealer where I bought it, they thought it was the aerial, but it is still leaking, has anyone had the same trouble?
hi I had the same problem only noticed it when I turned a corner and it started raining on me from the visor.
Anyhow it was the window seal all I did was 1 x tube of Stixall black colour silicone pealed back the rubber window seal at the top pushed the tip of the nozel in between the seal and pumped in the silicone as I worked along the top. Scraped off the excess left to dry and no more leaks.
Hope it helps
Hi, thanks a lot, glad it worked for you, was thinking of taking the parcel shelf down completely, but not being very good at diy... its still under warranty, so will take up dealers offer of replacing windscreen.
if its still under warranty take it in as what I done is only temporary I will have to have the windscreen done sooner or later
