Technical  Washer Bottle Leak
glossevans
Preston
Hi all,
I've just spotted that the windscreen washer bottle (or a joining pipe) is leaking on my 04 1.9JTD Multi.
After a very quick look round, there is nothing obvious to indicated where they leak may be.
Not had chance to start removing inner wing or weather shield from under the car yet, but was wondering / hoping that someone else has experienced this problem and could point me to any usual suspects?
Also, what is the easiest way to actually get access to the washer bottle, particularly where the pump or any pipes connect? No doubt these joins / joints will be the weak points. Hopefully, its just one of those that needs re-making.
Many thanks,
Matt.
If it has the front fog lights then remove the offside one and you have great access to the washer bottle pumps..
have you filled bottle & watched where water drips out?, i only ask because i have a peugeot (& multipla), the pug washer bottle leaked recently, it was near where the bonnet lifts, repaired it by joining the brocken part with short length of silicone hose
