Technical Warning Lights on Dash
Folkestone, Kent
Drove ~17 miles or so to an appointment this morning, somewhere around a third of the way, I noticed the lights on the dash
and a warning that the fuel cutout was unavailable :eek: , the other warning lights were the passengers seatbelt and the passengers airbag and S/S unavailable. After parking up for an hour (for my appointment), and restarting, the S/S was again available, and working normally (when I let it).
Having no prior experience with any warning lights, I just thought I'd ask before I stick MES on it.
I'm quietly thinking tailgate wiring harness.....
Still drives fine.
Fuel Cutout is related to airbag system ...... 😫 🫢
Still wouldn't harm checking that loom out.... good test is a good gentle pull of each separate cable from as far apart as you can reach.
Intact copper will withstand the pull, and a break will show itself very clearly by stretching
Could be either or both from what I've seen, shorting to adjacent cables and/or direct to chassis.
38526593_10212151810062851_3160791502574059520_n-jpg.101931
img_20180602_103951_1528133646630-jpg.101713
Ok, it defo needs a look then. Cars 2013, so I'm surprised it's lasted this long, unless of course it's been done before. We'll have to see.
Statistically you're only able to open your rear hatch (from new) 1761 times before problems start to surface
Do you know where you're up to ? :unsure:
Also it could be your heater matrix has sprung a leak , the airbag control module is directly under the heater matrix on the centre rail. o_O
Yep checked coolant, hasn't lost anything since adding that rad leak stuff whilst going around Europe last year.
Where were you losing it then?
The thing is if it is (was) a matrix leak, the leak could have happened (now stopped) and the symptoms (as with all liquid ingress on electronics) can take a while to surface
Yes, I was going around Europe on a bit of a mission, and developed a leak, which got worse as I continued on my journey. In desparation I put a couple of raw eggs in the system, which worked a treat untill I thrashed it down the autobahn, but by then I had bought some rad leak stuff from a petrol station. If anything was coming into the cab I'd smell it straight away. Leak starts about here Trip Around Europe .
My smell senses are really acute, I'd smell it straight away, and would have investigated immediately, knowing full well what happens if you leave water sitting.
Felt well enough to try investigating the rear hatch loom, the sun had warmed the car up nicely and I assumed it had made the rubber boot nice and soft for me to pull out. I was right, and upon investigation (both ends and sliding the boot along) there were no signs of cracking, or degrading, in fact it looked as good as new.
So I moved on to identifying the fuse, and checking it. All checked out fine, and to be sure I did actually test it, rather than just a visual.
So now I need to get at the plugs and poke some probs in to verify supply it getting to it, that it has a good earth, and the bus has comms.
If all those check out fine, then the ECU will have to come out, to be sent away.
Unless anyone has any other suggestions?
