warning light help
warning light help
david
when goin through my local "arc" carwash the other day i noticed the warning light for the brake circuit come on.
since then it has been coming on occasionally, especially when its been raining alot, but if i press down on the brake pedal it goes off, but then comes on occasionally flicking on and off.
advice plz?
i dont wanna take it to a garage then get my pants pulled down over the prices on things, my mate is a mechanic but hes on holiday so i thought id ask u guys.
Have you checked all you brake light bulbs ?
Rob
Mk.2 Marea Weekend 1.8 16v 115 ELX
Do you mean the brake pad wear warning light? I have this problem at the moment.I have disconnected the cable from the pad until i can have a look. All it does is make a connection to earth via the disc but I have plenty of lining on so i assume it just needs a good brush down
This happened to me after the my bravo went in for a service and i had the front pads changed, they didn't connect the little sensor back properly so my would flicker. Just take the wheel off and have a look, as axle said it may just need a clean.
Hope this helps
Chris
An update on the warning light: Just had a look and the wire going into the pad was brittle from the heat, also was loose in the pad. There was plenty of ferodo left so I just pulled it out. Due for MOT next month but this does not affect it.
S
2
597
Dark Lurker
P
2
518
Dark Lurker
J
1
776
Dark Lurker
T
5
437
M
