Hi Guys.
Each summer i get this weired idle problem on my 1997, 1,6 16V Marea.
When the engine reaches working temp the idle drops to around
2-300 rpm, barely able to run.
I read in the Fiat workshop manual that idle is set in 3 stages.
Start up:
Set mainly by coolant temp and battery level.
Warming up:
Set mainly by coolant temp.
Warm:
Set by rpm sensor.
I've had the butterfly valve stepper motor tested and it's working fine.
(also indicated by the engine is running fine at warm up)
I assume the rpm sensor is working since i get a correct rev read out on the dashboard.
Does anybody have any clue whats going on?
The engine idle fine at working temp in the winter...
I have measured the air intake and coolant temp sensors, they are fine.
Cheers Michael
Start up:
Warming up:
Warm:
Set by rpm sensor.
Cheers Michael
