VERY ODD
VERY ODD
dan the man
Hi Guys i have a strange nosie coming from the front of my car 2.0HGT MK1 i resently had the shocks changed on the front and ever since then i have had this nosie i have cheked all of the suspension conponets and can find nothing wrong the nosie sounds like some one has left a tin full of nails on top of the suspension turret and it comes from both sides can any one help?
dan the man
not related dan but have you had your car from new?
we both have nearly identicle registration except for one number they could be brothers!!
Hehehehehehe :) Join the club.
Its the front CV joint starting to wear. Its taken me about 6 months to track the bloody noise down.
Jack the front wheel up and hit it bloody hard with the palm of your hand (on the rubber bit obviously!) and see of it rattles. If it does reach behind and grab the driveshaft and then hit the wheel again.
Re: Re: VERY ODD
this is whats i was on about before, it does sound a bit like nails in a tin lol. so its the CV joint then?
is this dangerouse not getting it fixed??
matty
nice to know ya identified the problem though ;)
Re: Re: Re: VERY ODD
If it breaks off you could lose your wheel. If it's still intact you should be OK.
Shabash!
Re: Re: Re: Re: VERY ODD
Um.. how could the CV joint cause you to loose a wheel???
I asked the Fiat people to check it at the last service and they say its fine. There is very little play in it, just enough to make that bloody rattle. I'm going to re-pack it with grease sometime.
If it breaks surely you have fewer parts holding the wheel onto the car (or at least that was what I was told when mine went on my Punto).
Hold on, that was a Fiat dealer who told me.
Ho hum, always nice to cock up on here once in a while. I'll get me coat.
Shabash!
Re: Re: Re: Re: Re: VERY ODD
:) The CV joint is not part of the holding wheel on assembly.
IF the cv joint goes you will lose drive and pos gear box damage if the drive shaft come's out it will be flying around the engine bay
Re: Re: Re: Re: Re: Re: VERY ODD
Yes but they very VERY rarely 'go'. You get 1000's of miles of ever increasing clunking and if you haven't changed it by then its your fault for ignoring it. :)
What eventually happens is the ball bearings wear to such an extent that the inner part of the CV joint simply rotates without turning the rest of the joint and you loose traction.
Re: Re: Re: Re: Re: Re: Re: VERY ODD
Am I getting mixed up with the "bottom ball joint" or are they one in the same?
Shabash!
YOU are getting mixed up the bottom ball joint is at the bottom of the suspension leg and the track control arm to let you turn left and right.
The cv joint is three bearing's on a shaft in a housing coved by a rubber gaitor to keep in the grease in.
This shaft is from the gear box to the front wheels.
The cv joint give you drive to the wheels at differnat angles
Re: Re: Re: Re: Re: Re: Re: Re: VERY ODD
Its actually 6, not 3. The tripode joints at the gearbox are made up of 3 roller bearings.
Yup, if that fails your wheel will be left flapping in the breeze.
Re: Re: Re: Re: Re: Re: Re: Re: Re: VERY ODD
Dankoo Zur.
Shabash!
Validation! Nice.
Shabash!
Well 12 left and right.
And the 2 outter near the wheel's move in and out and the 2 inner are fixted. :p
The outer ones are fixed, the inner ones move in and out :)
Sorry, I'm just a pedant :)
Well Tom you must have fun driving in a straight line
A
9
809
M
M
168
myles
M
G
11
275
Darren
P
10
439
Anonymous
A
