I think that the answer will depend upon how the immobiliser function has been disabled. It is possible to purchase plug & play ECU,s, so that would suggest a negative answer, however I seem to remember reading on this forum, of at least one poster being told to retain the code receiver connection.After having the factory immobiliser disabled from the ecu does the immobiliser box need to still be connected 2.0 diesel 2005
So did your van start fine then you asked for immo delete on ecu? Now it wont start?
Or is there a whole back story?
no had gearbox off for refurb and after put back together came up with padlock logo on dash couldn’t get code so sent eve away to remove it and still won’t start fitted new crank sensor earth straps battery and starter motor injector relay think that’s all so thinking broken wire nowSo did your van start fine then you asked for immo delete on ecu? Now it wont start?
In initial post @Hol said that it is a 2.0 diesel 2005, so it has to be 2.0jtd. which is a PSA RHV.This is why we need the full story before diagnosis, including what engine series number etc. as different engine makes use different systems.
So a Peugeot/Citroen 8 valve engine, I have the 16 valve RHK version in an 08 Citroen Dispatch and previously in a 2010 Fiat Scudo.In initial post @Hol said that it is a 2.0 diesel 2005, so it has to be 2.0jtd. which is a PSA RHV.
Not mentioned in Wikipedia, but to be certain perhaps @Hol could check the vehicle VIN plate, where the engine type will be shown next to the heading "Motore". Unless engine has been changed this will be definitive.So a Peugeot/Citroen 8 valve engine, I have the 16 valve RHK version in an 08 Citroen Dispatch and previously in a 2010 Fiat Scudo.
The reason I asked for the engine series was I thought some used the Fiat 2.0 litre engine?![]()
