got a usb memory stick, and plugged in my laptop and its meant to be plug and play for xp & 2000, but it asked for driver so put the driiver disk in and oh thats just windows 98. :bang: what can i do?
Driver discs for USB sticks are normally only for 98 as they don't automatically have USB Mass Storage Drivers. 2000 / XP should plug n play, you tried searching for driver over the net?
It would help if you could actually list the manfacturer and model aswell
I don't know about lap tops if they have 2 ports if they have just swap the modem around see if that works had similar problem with a USB hub memory would not work swapped connection around with scanner all working OK
