frciy86
Hi!
I am in need of some help with identifying if truly my front airbag crash sensor (the one under the bonnet) is faulty or not.I have checked it via FES and it returns something like C03 front impact sensor fault intermediant or something like that.Now as far as i can tell the car never had any front crash damage, but I suspect that maybe the wiring is causing the problem.
Does anyone know where the wires from the front impact sensor feed in the D4 connector or how can I check if the sensor id good or not?!.I most know this because if indeed the sensor is faulty then I need to buy one or I will be spending a lot less by running 2 new wires to the sensor if that id working fine.
If anyone know this please help me...:worship:
