General  urgent brake help
raineuk
Newton Aycliffe
Yesterday my braking system started to fail on me. When I brake the car brakes then the pedal sinks to the floor and braking becomes weeker. when I release the brake and re-apply the same thing happens.
Thanks in advance
First Off - Check level of brake fluid reservoir for depletion; if low then check all wheels and the brake master cylinder for leaking brake fluid.
If no fluid leaks probably the seals in the master cylinder defunct - needs to be changed.
Peat
Peat
Thanks peat.
The brake fluid had gone. I sat for a hour after refilling pumping the brake pedal and the fluid hasnt dropped but the brake is still not working. I think its bus time until the snow goes.
Check for leaks at each wheel.
I had leaks at the rear left drum, I changed my rear brake wheel cylinder which was leaking, the whole drum was soaked in brake juice, causing the brake to feel like you descried.
Picture: Rear brake wheel cylinder from Firstline:
Search for rear drum brake for how to remove the drum.
