Uphill struggle
Uphill struggle
S
smoggi
newbie here. My problem is that when travelling i'm travelling uphill (it doesn't have to be steep)and have to slow down and change down a gear the revs seem to die so i change down again but there is no pull the engine just stops. Not sure what the problem could be. This is quite an annoying problem as i live at the top of a winding hill. Tried a few suggestions from the forum but no joy yet.( replaced air filter and used injector cleaner) any ideas would be greatly appreciated. oh yeah its a 96 brava 1.4sx
don't know mate. i'd wait for a reply off of tom he is a man that can
Re: Re: Uphill struggle
Jeez, not a bloody clue. Almost sounds fuel flow related.
If the tank is full does it do the same?
Re: Re: Re: Uphill struggle
Is your fuel pump working? Does the car make a whining sound when you turn your key for the 1st click?
Joske
the tank hardly ever gets below half
Re: Re: Re: Re: Uphill struggle
not that i have noticed
It needs to make a whining sound, what it does is it pressurizes the fuel tank. Its best to leave your door open, sit in the car and turn the key once. Then listen for the whining sound. No sound then its not pressurizing. Hence thats your prob.
Joske
Re: Re: Re: Re: Re: Uphill struggle
Joske, No. The pump does not presurise the tank, it pumps fuel to the engine bay where the pressure regulator is. the tank is actually at negative pressure when the car is running.
If the pump was not working then the car would simply not run.
Does it accelerate OK on the flat.
Re: Re: Re: Re: Re: Re: Uphill struggle
accelerates fine most of the time on the flat. Did have a flat spot in the low revs but doesnt seem as bad now.
Re: Re: Re: Re: Re: Re: Re: Uphill struggle
Strange. Really does seem like fuel pickup problem to me.
Might be worth popping the fuel pump unit out of the tank.
Re: Re: Re: Re: Re: Re: Re: Re: Uphill struggle
forgot to mention get really crappy mpg
Re: Re: Re: Re: Re: Re: Re: Re: Re: Uphill struggle
OK, sorta important that bit!
I'd go to fiat and let them have a look at it, would be worth the £40 or so.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Uphill struggle
I know its my answer to everything :)...but...
...Or you could try resetting your ECU...
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Uphill struggle
not again.........lol
Martin
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Uphill struggle
Could be the dreaded 1.4 old worn out throttle body.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Uphill struggle
"the tank never goes below half"
On a 1.4?? Yeahhhhhhhhhhhhhhhh! Somethings definately wrong there :)
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Uphill struggle
just got back from having it checked. bad bad news needs new front pipe and cat and lambda sensor. The sensor had been disconnected.
I HAVE BEEN SCREWED GOOD AND PROPER
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Uphill struggle
Thats not too bad, could have been alot worse.
Are they doing the work?
S
7
267
Shaun Cook
S
S
9
216
Anonymous
A
L
12
237
A
