upgrading my punto mk1 17td
cicco2
hi i would like to know if i can add a bit more power to my punto mk1 turbo diesel ...most important a bit more torque...ty
:wave: Hi, and welcome to the forum. I'm sure a lot of owners have wanted the same and luckily with the turbo diesel it is quite easy to achieve this by either having the ECU remapped or by adding a tuning box. I'm not sure how easy this is to have done in Malta but if you check out the Punto section of the forum, I would hope that you will find all the information you require. If not ask the question and I am certain that you will receive many positive replies.
The added benefit of having this ndone is that you should also achieve better fuel consumption when not using all the extra performance.
