Update on Total Closure fitting for MK1 Bravo
J
jay
Hi all.
Just fitted EJ's Maplin / Microscan Total Closure system and it's **** easy once you know which wire to use. The haynes manual is SOOOOO wrong (with the colours) and David's guide is spot on apart from the window motor for the left errr window.
Instead of Green / White, the wire is actually Red / Green. We had the hard task of splicing most of the wires to find the right one so you dont have to.
If you havent got a soldering iron or crimp joiners etc, you may wanna invest in some connector blocks. I used both crimp, soldering iron and connector block depending on how tight space was. Also dont forget insulation tape!!
We took some pics and made a video. Post that later. Now i'm gonna soak in the bath.
Jay
thanks guys, once i've had a butchers at the vid and pics i might tackle it again
Re: Re: Update on Total Closure fitting for MK1 Bravo
any news on the pics/vid?
