up date but got a problem
T
trev
Just an up date got the car back today
Body work is ok new tail gate, new rear bumper and rear panel
Side panel repaired :)
But got a problem :(
My key remote battery is flat ok when the car went in bummer
2nd key will not open the door by remote�..checked the fuse by steering wheel all ok
No interior light��. bulbs and fuse ok
Wing mirrors will not work�.. Fuse ok
Roof consul e.g. the lights for the key codes
when the interior light switches are in the o position
The light is on put the key in turn on the light is out
And still no remote
And the strip under the front bumper is hanging off grrrr :(
any comments welcome
trev
well i'm ragin too because i just had to replace the siren on my alarm. bloody thing was £80 !
That was half my cambelt money! so no cambelt THIS month then :( Thats 3 months in a row i've put it off due to one financial calamity or another (had my MOT last month which was £90 all-in)
Anyway, all these electircs you've got not working is cause for concern. Were they all broke before you had the car bodywork fixed up?
Buzz
The champion of the Bravo 1.4, and owner of a Bravo 1.8
Member Page
Hi Buzz
All the electrics are working fine before the car got hit up the rear and going to the bodyshop
"That was half my cambelt money! so no cambelt THIS month then"
What would you rather have, a siren for the off-chance someone will break into your car or a new cambelt?
I know which would be my choice, and it don't go wee-waa-wee-waa!!
Mark.
Council estate lad.
And proud of it!
Member of the Guild of Experienced Motorists.
a yeah, i know what you are saying, and its totally reasonable, but the remote died, which was why i was there in the first place. It has been silent for several weeks ;)
No remote = no way to use car, at all, ever. Clifford Concept 650, so 3 immobilisers. Its pretty much impossible to get round it too, because the valet code i was given doesn't work. There are a thousand combinations to try, so much patience required, as iirc you can only do 3 incorrect tries every 15 minutes!
Buzz
Member Page
Found the problem Earth wire off /cut in the boot
Fixed together all working light, mirrors, alarm
But the locking button on the door is up/down
3 or 4 times alarm is set door are not locked
If I try and lock the door by key only one door
Will lock with the wire together?
Undo the wire and lock the door by key two doors will lock
But no alarm, light or mirror
Has any one else had this problem?
If so how do did you fix it
Trev
W
930
wakka
W
1
7K
Dark Lurker
5
919
Darren
T
1
821
Joseph
J
