A
Anonymous
FIat Bravo 1.4 sx 1997
65K
I was driving to work today and found i couldnt select a gear, i pulled over thinking that the cable had snapped so i checked, it hadnt i got my friend to press the clutch pedal in and could see that it was moving the lever near the gearbox. I started the car in gear and drove in second gear about half a mile home, i got home and the tried to select a gear again and it worked !, drove around the block and began to notice a smell similar to burnt toast ! at which point there was a clatter and i stopped the car,,, i checked the brake/clutch fluid resevoir and it was fine,,,,,
any ideas as to what the problem could be before i get ripped off by a garage would be appreciated
65K
