Untitled
Untitled
J
Ja
noticed tonight brake light out, also noticed very soon afterwards that I couldnt work out how to get to bulbs... before i snap some flimsy plastic could someone help me see the light (so to speak).
I assume you are on a Bravo?
In the boot, look where the lights are. You should see a panel held on my some small butterfly nuts in the centre of the panel, top and bottom. Simply turn these (I think there are 2?) and this will then allow you to pull the panel out - should not need much effort.
Re: I assume you are on a Bravo?
I found my lights a bitch to get out the hole!
And my rear circles of lights tends to keep blowing 2 of the bulbs, not the same 2 just any it fancies!
Re: Re: I assume you are on a Bravo?
cheers, was late when i checked, on morning inspection found previous owner had mashed up butterfly clip, and yes the lights were quite trickey to remove/replace
C
3
7K
Tommy K
T
2
6
500
paull
P
539
dexter
C
1
600
Chris
C
O
2
435
orangebravo
O
