Untitled
  • Thread starter neon bar, what can i wire it to???
  • Start date
Untitled
N
on my sub box i wanna put this neon bar thingy on it, but like most crap from shops it connects to the cigarette lighter bit, what can i use as a substitute, im quite happy to snip the end off the neon wire but where can i connect it, i thought the stereo remote....
any ideas?
Re: Re: Untitled
Any 12v source will do the job. So amp power cable, side light cable, boot light etc.
Re: Re: Re: Re: Untitled
the bootlight for the possitive connection and for the negative, the chassis of the car. If you do this it will only be on when u can see it!
Re: Re: Re: Re: Re: Untitled
i would take the boot light out and wire it there. i wouldn't use the switching wire from the head unit as this can only take a limited current and if you exceed that you could damage your head unit.
Re: Re: Re: Re: Re: Re: Untitled
I would go with Chris & Craig on this one, good bit of finkin' that.
Daz
Re: Re: Re: Re: Re: Re: Re: Untitled
i wired mine into my bootlight last week, 2 minute job and looks the badgers nadgerz :)
Re: Re: Re: Re: Re: Re: Re: Re: Untitled
Only if you don't have electric mirrors.
If you lift of the panel infront of the hand break, (that hold money)you'll find a wiring loom,
Black is earth and blue with red and red with blue are live, i wired my dash neons with this and put 2 micro switches onto the panel
Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
cheers people ithink ill go for the bootlight, as the subs in the back, i wondered what them wires were for under the coin holder, at least now i know, cheers again
[\/]atty
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
wonder how many times i would get pulled if replaced the break light at the top with a bright blue neon bar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
twice as often as you use the middle pedal.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
I've got 2 10" neons that i'm mounting above the footwells, how difficult is it to connect them to the interior lights so they come on when the doors are opened?
sy b...
i have found the loom that you mean, i dont have elecy mirrors, does this mean that the 2 connectors under the coin holder that are free with four wires in each can be used? ive just had a play around and i cant get it working, the boot light works fine, cheers for that by the way but my mate has also given me 2 neon tubes that i also want to power up and i think under the coin holder would be ideal if only i could get it to work
C
3
7K
Tommy K
T
2
6
475
paull
P
517
dexter
C
1
586
Chris
C
O
2
425
orangebravo
O
