turbonutter
hi everyone need advice just unbolted alternator how on earth do u get it out from the back of engine thanks
			always took the inlet manifold ect off when getting to them
I didn't know it was that bad in the turbo. On the FIREs you unbolt the alternator and it drops down onto the drivers side driveshaft. It looks like it won't come out (like the turbo, not enough room to pull it out from the top), but if you pull the inner plastic wheel arch enough you can just make enough room for it to drop out from underneath.
I have a feeling this won't work on the turbo as the split driveshaft intermediate bearing will probably get in the way. But might be worth a look?
