Hi everyone,
After pulling the engine out to have welding done. I changed the belt tensioner plugs and leads etc. Plumbed it all up and no bang.
This is were Im at any suggestions will be most grateful.
I have set the crankshaft tdc up and the camshaft tdc together. Have set the distributor to point at plug 4 you know with the little groove slit on distributor body.
Have fuel and sparks but no bang.
Not sure if I have done something wrong with timing or ignition. 1342 is the order I have the leads. I am now unable to remove the crankshaft pulley as the engine is all back in car and I don't have a air gun to get it off. Though I went by the little pointer and slit in pulley. Also the notch is aligned with the tdc sensor.
I am pretty sure my vacuum leads are correcly fitted there was only 2 I was unsure with the one which goes into the t junction which feeds into the inlet msanifold next to fuel return thing. and the other which goes directly under the throttle body. This one I fed to the swan neck you sent me and the other goes to the dump valve and fuel return thing.
I ken its really hard to diagnose stuff without seeing it I can take pictures but is there any basic tests I can do to make sure the ecu's are working the only electrics I dont have connected is the 2 wires to gear box reverse light I expect and the oil pressure sender.
Hope you spot a simple error or can think of something I missed
Cheers,
Tony..
Cheers,
Tony..
