Technical Uno Turbo Mk1 and Mk2 heads interchangable?
sdlsaginaw
Cottage Grove, Oregon
Title says it all. Can a Uno Turbo 1372 head be used on a Uno Turbo 1301 block with a 1301 head gasket?
EDIT: OOPS - the turbo head I'm looking at came off a "1400", which I assume isn't the 1372 Uno. Will this head fit the 1301 Uno Turbo block?
Is that in regards to the Mk2 head, or my updated question regarding the 1400cc head (would that be a Punto??).
The guy claims it will fit the 14-bolt X1/9 1500, but that doesn't seem right because it would make for a tiny chamber over a big bore.
He also says "Fits a Uno too", but alot of people seem to be using cracked Mk1 heads for there to be newer options available.
WAY too expensive to import a head into the US only to find it doesn't fit.
Are there alternatives to the original 1301 turbo head, which appear to be getting rare?
Sadly I already imported the Mk1 engine a few years ago so it's what I'm stuck with. Mk2 wasn't an option at the time due to a "20 years or older" rule.
Even if I were to import another engine now I would be stuck with 1993 or older. It's just too expensive to get another old pile of iron.
