John Black Cat
- Joined
- May 11, 2013
- Messages
- 2
- Points
- 1
Hi I'm new to the forum. I've got a Fiat Uno ie Turbo MK ii (1995 model year) which I have cut the body off and put a widened, stretched Minivan body over. It used to run perfectly - however!.....it's been sat for 6 months, and now will not start. Got a spark, but got no power to the fuel pump or the fuel injectors (they're not opening). I've manually powered the pump and there's loads of pressure at the rail - but the injectors just will not open! The Fiat part of the car (i.e. everything except the bodywork is totally standard)...
Haynes manual is ****! Does anyone know where the fuel pump relay is? I can't find it anywhere, and assume it must have one? And would this have an effect on powering the fuel injectors?
check out blackcatmotors co uk for pictures of the van.
Any help on this MUCH appreciated!
