I have a kit car with a MK1 Uno turbo engine in it. The engine has many mods but it is running on standard fuel injectors.
Went on the dyno at Interpro (Bristol) today.....managed 191 bhp and 187 ft/lb which is bloody good but this was only at 5633rpm!!!
however...unsurprisingly....beyond 5633rpm it starts to go lean. This is with the injectors wide open. So....as expected I need bigger injectors to be able to get it driveable. This will push it nicely over 200bhp - not too bad at all!!
So the same old question again....what injectors will fit straight into my MK1 but give me 10-20% higher flow rate? Anybody? I know this has been asked many times but I can't find a definitive answer...
Also can anybody remind me what the difference in flow rate is between the MK1 and MK2 injectors, and if the MK2 injectors will fit onto the MK1 fuel rail?
From searching this forum I have found that the following may work:
1) Saab 9000T injectors (although quite a few people think that these are just too big) - what is the flow rate on these?
2) Punto GT injectors - are these a straight swap?? And how much bigger are they??
Many thanks,
B.
Many thanks,
B.
