Technical  Uno Rust Problem
Northern Ireland
I was washing my previously spotless Uno after a 500 mile round trip this weekend when I found a rust bubble. After poking at it a bit it appears to be more than just a rust bubble.
What would be the best way of tackling this before it gets worse? Could I do it myself? I have very limited experience of this, or would a bodyshop be the best bet.
Thanks in advance and here's a picture of the problem.
e: [email protected]
w: www.irishfiat.net
<h6>
Click here for pictures of my Uno </h6>
Bubbles are bad news:
the tin worm has got out from under the trim - possibly the paint was damaged when the trim was fitted.
Years ago we had a UNO and there was a bubble at the base of a small glazed area behind the rear door. I peeled the rubber back, popped out the glass, dug out the rust (which was a lot more than expected), repainted it and put it back together again.
It didn't come back in the few years we had it afterwards.
I suppose I'm saying you need to remove the trim strip, and dig :)
I've got no idea how that piece of trim is fixed on yours, sorry :(
Regards
John H
Hei.
I think these trims are just snapped on. Because the one closest to your picture has popped up (on my car). And it's impossible to get it back, because it's broken some sort of way. You have to dig out as much rust you can, and add some stuff which "transforms" the existing rust into a black metal. At least I did. It turned completely black, and was overpaintable the day after. No signs of it coming back.
Morten.
Steve
You are better of touching up such a small area as u may get over spray and it will not be as glossy as the rest of your paintwork. As Morten says sand it down to bare metal then use a rust inhibitor, gel is best then light sand and a few coats of touch up.
Pete
ps where r u from I am orginally from Dublin
