General  uno pcd conversion
kert
Indonesia.
<font face="Verdana">hey all,
it's utterly impossible to find a set of 15" wheels with 4x98 pcd for my UNO here in Indonesia. Literally NO ONE carries aftermarket wheels for fiat here--which is understandable, u don't see many Uno around the street of Jakarta. Many places recommended me to convert the pcd setting into a more common 4x100.
My question is: has anyone have had any expirience with this? Should I aim for an actual physical conversion of the wheel-base? If so, is it expensive and well worth it? Or should I go for an adapter instead? Or does anyone have a different solution...?
I'd like to do this correctly, no wobbly studs.. just yet hehehe..<font face="Verdana"></font id="Verdana">
Much thanks guys,
kert.-</font id="Verdana">
you use what are called wobbly bolts or nuts, they have a lose fitting tapered washer that will allow you to use wheels of 100mm pcd.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
now these wobbly bolts... can i find them on any car/wheels shops, or do i have to go to fiat stores? hope they're available here..
and do they cause any vibrations when driving or any other side effects? i guess converting the pcd is pretty much out of the question eh..?
thanks,
Kert.-
you get them from car/wheels shops here fiat don't do them, if you can not get them post up in the parts wanted section, someone may know an online supplier.
