Technical uno NA using turbo valve spring ?
yoes_p
jakarta
hi folks,
myfriend is in process of rebuilding engine mk2 '93 uno 1.4 (carb). got some parts collected (engine gasket set, piston rings, valves and springs,etc..)
does anyone know about mk2 uno turbo valve spring will fit on non turbo mk2? if it is, what hazzle will it encounter later? does uno2 split collect and spring cap will hold tight the spring in its place?
TIA
i see that, doesnt realize both diameter are different. in that case, i'll leave it all as it should. standard.
thx buddy
