Technical  Uno Mia
Technical  Uno Mia
Diile
I have an uni Mia. The car fan belt fell off and I had the other replaced. I am not sure if this is linked to the matter, but the thing is. When I drive my car, it slows down when I go uphill. Even when I step on the accelerator, it needs few seconds to catch up on the speed. When I am travelling faster, then it catches on speed. Struggle with power when I change gears. I have also replaced the module as it was becoming hot, so I thought that may have been a problem.
I am also not sure if this could be on the previous problem that was found by the mechanic as he was replacing the top gasket, as the car was overheating. It was as if the pistons were grinding against the top. However, the mechanic said we can only fix this later should the car be smoking and we will them take it to engineering for the rings to be changed and all.
Please advise where possible and give advise.
