General uno leaking water into interior
Does it have a sunroof mate?? if not check the windscreen rubber beau, best way is maybe get someone to spray a hose over the bonnet and check inside to find where the leak is. You might find that sometimes where the water is supposed to drain gets clogged up with leaves and stuff so this can cause it to leak into other areas.
:cool: F R O $ T Y
:cool: F R O $ T Y
no sunroof, and i dont really have any access to water near it lol i think next time it rains il have to go sit in it :p
my old mk1 used to leak water in through the windscreen, no obvious holes from the outside but the rubber was knackered, i just used some black duck tape and it stopped! lol
same with my old uno got some water added a small amout of milk to discolor the water slightly so i could see any leaks more easy and it was through the windscreen also
Open the bonnet and remove the big plastic panel that covers the windscreen wiper motor. You should then be able to access the holes to reach down and clear the drain hole for the heater bowl of leaves. I had this problem on my Mk2, as the drain hole was blocked the heater bowl filled with water, which the heater sucked in and pumped out through the footwell vents.
Matt
