Technical uno injectors
saab 9000 turbo injectors fit. theyre called bosch "red" injectors. not worth changing them unless u have many other mods too. ive already got an uprated fuel pump, FSE adjustable fuel regulator and i was maxing out the standard uno turbo mk2 injectors with the boost i run, so after alot of looking about, i found the red injectors the ones i needed so i can now run more boost.
Dunc
Larger Injectors are not a mod you add to get power. They dont giver more power, they only supply more fuel to support the gain you may get from other modifications.
Saab 9000T injectores are Bosch 280 150 712. Ive tested these out and they are far too big for anything under 200BHP unless you have an aftermarket ecu. Bosch 701 (punto GT) are a better choice, not quite as big. Ive got them running in my uno. Still way too rich with 180BHP
