General  Uno Engine & Gearbox Specs
kbooth1
Hi, Sorry to intrude on your forum but I'm developing a race car for the 750 Formula which uses the Fiat 1108cc Fire Engine. Could some one advise me about;
If the uno ever contained this engine?
Was it always fuel injected or is there a carb version?
Also;
Did the uno Have a 4 speed box?
What was the gearbox number?
Could you separate the Diff from it?
Any other info will be greatly appreciative e.g rod or cable gear change
Karl
Hi Karl,
I also race a fiat uno but it uses the lampredi design 1498cc sohc engine and strada type gearbox.
To answer some of your questions:
I can't swear that the 1108cc fire early versions had 4 speed, but certainly from 1993, they were 5 speed as standard, with a final drive of 3.733:1
I can confirm that from at least 1993 onwards (but fairly sure all 1990 mk2 unos onwards were the same), they were single point injection (due to having compulsory cats fitted)
Gearbox numbers for pre 1992 were C.501.5.10
After 1992 were C.514
possibility in easily removing Diff on fire engine-no idea, but they certainly do on the strada type box that were used on the 1301 and 1372 and 1498cc versions of uno.
The pre 1993 1.0 unos were 4 speed as standard, so I don't know whether you are allowed to mix and match gearboxes.
The earlier 1100 unos (mk1's) were 1116cc but this was the lampredi design sohc engine, and used the 'strada' box which is not compatable with the fire engine.
Unsure on linkeages in the 1.0 and 1.1 fire engines, but I believe they may be rods which go to the bottom of the gearbox.
I hope this info is at least gives you a head start!
if you want any info on spares etc, I may be able to point you in the right directions, esp a nice set of 13" minilite alloys I was offered that may be still for sale, just send me a pm or e-mail [email protected]
Regards, Chris
Hi Karl, Just to add to Uno racers comments I can tell you the following:
If the uno ever contained this engine? (1108cc FIRE)
Yes, it did. Only on post 1989 mk2 Unos though. You will find they are called '60' models. Mk1 60 models used the 1116cc Lampredi engine (totally different to the FIRE). 45 models had the 999cc FIRE, 70 models had the 1299/ 1301/ 1372cc Lampredi engine as did the Turbo. Mk2 Selecta models continued to use the older 1116cc Lampredi engine.
Therefore the Uno you want to look for is a mk2 '60' model with manual gearbox.
Fuel injection wasn't compulsory on 1108cc models until 1993 (when Cat convertors became mandatory). 1989 - 1992 mk2 '60' models could be had with the carburetored 1108cc FIRE engine. Post 1993 models all had SPI.
Yes, but only in the base models. There was basically three models. Base = denoted by just a number e.g. 45, 60. 'Super' models all came with 5 speeders = 45S, 60S. Then there was the top of the range available as an SX = 70SX (also a five speeder but a different bellhousing). The high performance turbo was known as the Turbo i.e. and used a Strada derived gearbox and then later on a Tipo type (I think?)
If you want a FIRE engine and four speed box you need a base model Uno (e.g. just a number) in 45 or 60 spec. All mk2 45/ 60 models will have FIREs, but mk1 60 models are no good (as mentioned above) and some of the mk1 45 models came with the very old over head valve engine. Mk1's are getting very hard to find now, and if a three door shell comes up in good nick they sell for good money! That's because all the Turbo boys are looking for clean shells to reshell their rusty Turbos into :rolleyes:
I think Unoracer covered this in his post!
I don't see why not. The mk1 FIRE and Lampredi engined Unos used the same type of gearboxes but with different bellhousings. If the 1500 Uno could have its diff removed then no doubt the 999cc gearbox could have it removed as well. I've never done this though so don't quote me!
All Unos used rod change mechanisms as far as I know. Two rods are used, one for side to side selection and one for back and forwards. However, early mk1's had the rods going under the car to the bottom of the gearbox ('bottom change') whereas later mk1's and mk2's had rods going through the bulkhead to the top of the gearbox (top change). Later mk2 gearboxes were also Tipo derived (I think, or maybe Punto), and all later models came with hydraulic clutches (all mk1's and possibly some early mk2's used cable clutches.)
Karl
Glad to be of help! Post some pics of your race car!
By the way, there is plenty of tuning info on the FIRE engines. You're more likely to find info in the Cinquecento section as all the 'Sporting' models were fitted with the SPI 1108cc FIRE engines.
Chas
Hi
I'm urgently looking for anybody that can give me advise on 1993 uno fire 1100 gearbox (the bottom change)
The car just got stuck doesn't want to reverse and slips in first and second gear on pull away.
My mechanic tells me it is the clusters inside the box .
Please i need urgent advise as my car makes my bread and butter .
I'm in Cape Town .
My contact number are 27 84 620 7687
[email protected]
