fiatsforever
hi, does anyone know if it is possible to put a 1.4ie mono jetronic engine in a 999c fire uno, what would need to be transferred from donor car, is 5 door uno basic same chassis as 3dr, except for doors, thanks
wouldn't the 1.6 tipo carb engine be too heavy, what about the 1.4 tipo carb engine is there such a model, would this work with the existing fuel tank, and would the drivetrain fit to the uno hubs, thanks
--If you won't fit cat it would have even more. --
On a typical 3L engine , the power lost due to flow restriction through a cat converter is less than 5HP.
In a small engined car , its likely to be a lot , lot less.
My recommendation is to leave the converter working and in place especially if it is a requirement under law in your state or territory.
gW![]()
