General uno common rust spots??
uno_94,
"it seems strange that since starting this thread all uno owners have rushed out to there cars and gave it a gd once over"
Good point!
Here are some of my 'rust spots' common to the five Unos that I've owned :)
- Take off sealing rubber around hatchback. Rust tends to start above/behind rear light clusters.
- Similar to above, wash off mud inside rear wheelarch, scrape off loose underseal, take out rear light cluster. Look for rust holes here (behind bumper, which can also come off easily if needed).
- Similarly, look inside below rear hatch lip. I don't think this area received much paint at the factory.
- Look under front wing top lip about 5cm forward of bonnet hinges. The inner wheelarch (that the wing bolts onto) tends to rust through here.
- Remove sealing rubber for rear side windows (3-dr). Check that rust is not starting at the welded lip.
- Remove seals for door window glass. Again, check for rust at the welded lip covered by the rubber.
Rectification for all above places is simple: chip and wirebrush the rust away, paint with anti-rust paint, cover with Waxoyl (as Chas suggests). These spots are fairly hidden (if you catch them in time).
Then we have the serious rusting areas (!)... these need WELDING to rectify:
- Edge of the floor, where it meets the sill, on the left side. You notice this one as you try to jack up the car with the standard jack... the sill bends... :eek: (I have seen three Unos with rust here)
- Top of the sill, under the door. Remove the sealing rubber and clean up - if no holes or only holes 5p-piece sized, then treat as for other rust spots above ;)
- Front crossmember near gearbox mounting - has a haphazard construction that leaves spot welds exposed, particularly after crash damage. (one Uno like this)
- Rear shock towers as already described (you need to remove rear seatbelts, parcel shelf supports, and carpet/plastic that covers the wheelarches).
- Door bottoms (very common)... In the best cases, the frame disappears completely and the door loses all its strength, leaving the skin hanging free.
I think these are the most common areas... I've also had Unos with rust in the roof edges, under the windscreen, at the front of the sill behind the front wing, and the tailgate (so rusty in one case that the rear window popped out)...
-Alex
good post alex! ill be chcking alot of those places this week on my new uno
so far ive spotted rust on the upper sills, bottom of doors (not bad though) on the passenger door hindge, side of th tailgate, rear arch lips (although the inner arches look ok byt i need to take hte carpet out fully to get a good look), front arch lips... and thats all i can thing of at the moment. its had a scratch on the front wing which was never treated as its rusted too...
Hey Bushboy,
I love your description! It's time we started being more honest about our cars in line with yours! :)
____________________
1301cc Fiat Uno Turbo i.e. MK1 with slightly clunky MK2 gearbox, worn out clutch, dead battery, and cracked windscreen,
Original alloys, fronts sanded, polished, and coated with yellowing lacquer. Rears still flaking away merrily. Have some lightly-scuffed 15s to go on,
Lowered about 50mm all round, slowly sinking on the South African '40mm' springs,
Left side in primer and with Turbo trim removed,
Headlining stapled into position, hanging down at the edges,
Squeeky standard seats,
Surround sound with massive 4" speakers in rear and ancient Pioneer 2-way 6.5"s flapping about in the front door cards. One door card with plastic plug where the winder was,
SONY MP3-playing CD player with the shutter front - brand new!
Rattly standard dash and broken loose steering column covers,
Oh, and a couple of shades of white from my previous replacement front wing...
-Alex
Louie Bee said:
OMG !!!
Bryne do you have a leaky sun roof or has it come in through the floor :confused:
Well, basically it HAS come through the floor.. :)
As I said, driving on salty roads during the winter isn't a very nice treatment for any car. The owner before me hasn't taken care of it at all as it seems.
I have, however, seen a lot worse.
You don't know how lucky your cars are that they are driven in warm countries! :D
