geeker
- Joined
- May 26, 2005
- Messages
- 16
- Points
- 7
Hokay,
So some of you may have seen my posts about my lil' Uno 45 - I had the head off it a few months ago because it bombed out on it's MOT, and a few people here gave me a lot of advice - thanks guys
Now, I had it all back together, and took it out to the MOT test center to get it's welding done and then it would pass it's MOT, no probs (even got a mechanic to check it over for me the day before). So i'm driving down there, and it cuts out. It was a warm day, so I pulled over and waited - I know the distributors sometime go weird when they get warm...
2 hours later, my dad is towing me home in it - the ignition system has totally died :-(
I got the coil off and tested it, played around with all the HT leads, had the distributor apart and everything seemed fine - it all points to the 'Breakerless' black box that sits next to the coil.
Over the next week I'd been to nearly 20 different yards trying to get a replacement, and I still can't find one (this was a month or two ago - had no money recently so put the car on hold until I can get back from uni to fix it).
As far as I can tell, I have 2 options.
1. Someone can help me get the replacement - from what I've seen at different yards/parts stockists, these are very hard to get hold of, so I'm hoping someone might be breaking an Uno with a similar ignition system. Here are pictures of the coil and the black box that I need to replace... Like I said, this seems to be the hardest option and I've exhausted all of the sources I have atm. My question for this option is... Can/Is anyone willing to sell me the parts?
2. A guy I knew from college has an Uno and has reliably informed me that it is possible to simply change the distributor and the rest of the ignition system with one out of a slightly newer mark 1 1108cc model (mine is the 999cc), which is apparently slightly different and easier to obtain.
A few other guys I know reckon that it is possible, but I'll have to change the camshaft as well as the distributor drive is slightly different - this being possible due to the fact that the 1108 and 999cc engines share the same head, and the difference in size is in the cylinder stroke, so they are essentially swappable (although the new camshaft will have a slightly different profile and so would let more fuel in - can someone verify this?). It would be nice if this were possible as I've seen literally hundreds of newer Unos with the different (clip-on as opposed to screw on) distributor cap (and I assume, different distributor), and I can probably get the parts pretty sharpish...
Sorry for the long post/rambling... It would be great if anyone could give me a point in the right direction here (My uno manual is in a box at home, packed away because I'm going to uni at the end of the week
Thanks again,
Matt
Thanks again,
Matt
