first off, i have been searching the forum for info on this but it seems no one has had the problem i am getting.
oh and also, the search feature i think is broken, i search for loads of keywords but it keeps coming up with no results
anyway.
few weeks ago i did the engine flush + oil change on the car. at the time i had no radiator on. so i stuck the old one on and filled the system full of water just to use temporary. the system bled its self fine as soon as the temp got to around 90. at this point in time i had already replaced the thermostat.
(the pump really flung the water round, when it bled the whole top pipe started to shake and it all bubbled up through the expansion tank.)
now, for the past 2 days i have been trying to bleed the system, now i have a new radiator and coolant.
thing is, it just wont bleed. nothing i do will make it bleed. ive squeezed every hose many times i have revved the engine and squeezed the hoses but nothing. the engine has been getting hot, up to 120.c at one point where i forgot to check the temperature while trying to bleed the system. the thermostat opens as the pipe gets too hot to touch but the radiator is not hugely warm, and the fan heater starts off nice and warm but then goes to really cool.
i have also drained the cooling system a few times and refilled it. i have even parked the car in differnt positions pointing up hill and down hill. but still, no pumping of water.
like i said, i know the pump is good as when we used just water in the system it bled fine with no issues.
i know theres no bleeding points in this system, but is there anything i have missed?
anyway.
