Technical ulysse sick running on 3 cylinders
mojoboogie
ellistown
Hi guys,new to the site
i've just purchased a fiat ulysse jtds w reg which as developed a fault it seems to be only running on 3 cylinders starts fine off the key but runs rough
no masses of smoke from exhaust and no oil in water so i'm at a loss and hope you guys can help me out
Cheers Andrew :worship:
Don't know whether I can be of any help, but have you had a compression test done. Could it be a stuck valve?
You state that it starts easily and does not smoke. Does it run roughly from start, or does it develop the rough running after startup?
Hi i too have a 02 plate ulysee also running on 3 cylinders but do have a cloud of smoke when driving and starting up help really needed thanks xx.
:confused: Mojo if no smoke etc i would go for diesel filter or contaminated fuel. If a injector was completly gone it would smoke and smell of diesel. Stuck or burnt out valve is poss butwould normally smoke a compression test could find that.
Leakylou is yours a petrol or diesel (jtd) and what colour smoke white blue grey or dark black clouds????(n)
its a diesel and has no power when accelerating, but when i put my foot right down a burst of power comes and so does large cloud of black smoke !!!!
(n) leakyLou sounds more like a turbo related problem than injector related issue.
