Technical  Ulysse problems Help! misfire
dogboy
Hi my ulysse 2.0 16v auto has some faults and drives like it is misfiring some times , the garage want £250 to investigate after I have paid out for the diog's but i think it maybe just leads or spark plugs can I have some advice please as unsure , here is the fault list , its lpg converted but drives the same on either gas or petrol . Much thanks for any advice really dont have this sort of money they thinks its an injector £420 all in or low presure i assume thats the gasket lots more ....
fault 1 exhaust gas ( think this is anti pollutions system but has always said faulty) permanent fault
fault 2 air pump relay control sc+ permanent fault
fault 3 injector control 1 sc- permanent fault
fault 4 fan unit status not specified permanent fault
fault 5 auto gear box intermitent ( came up on screen once only, no problem )
fault 6 inlet manifold pressure sensor signal sc+ ,oc intermittent
fault 7 air pump control. not specified permanent fault
fault 8 injector control 1 . co permanent fault
THANKS AGAIN TO ANY ONE THOUGHTS PS ARE THE FIGURES REASONABLE FOR INJECTOR AND INVESTIGATION ?
