General  Ulysse Head lights
UlysseRed
Hi, Does anyone know how to change the bulbs in the head lights of the new Ulysse? I tired of paying £26.00 quid a pop to my local dealer to change them and because the lights pulse it goes through bulbs much faster than my Alfa which is six years old and still on the original bulbs. The Ulysse has just turned 2 and is on its forth new lamp.
You'll C red
If you are talking about MK2 it can be done easily with the aid of a mirror.
Just open the relevant cap, disconnect the connector and release the retaining spring.
For the front fog lights, There's no way to do that other than removing the bumper and then removing the entire headlight unit :bang:
I have changed the headlight bulbs a couple of times, it is tight but you can do it by feel. Make sure you disconnect the connector before releasing the spring or it is difficult to get off.
I did change the passenger fog light bulb without removing the bumper etc, you have to unbolt the headlamp just enough to move it slightly and get your hand in. It is tight, but you can do it.
