Technical Ulysse Cambelt
Johandv
Vanderbijlpark
Hi, I need to know how to change the 1999 Ulysse 2.0 El cambelt and if it is neccesary to change the tensioner as well. My last change was 90000Km ago. Please help and advice
Johandv
How competent a mechanic are you?
As I would not attempt such a precise operation without at least a fairly good mechanical knowledge.
You can get a full guide on the mk1 ulysse someone here may have a pdf file to assist you.
Pete
Hi Pete
I am not a mechanic but have dirtied my hands troughoutb the years with som oil and grease. Have done cambelt replacements on other makes but have not worked on the Ulysse. Need a bit of guidance and at least the correct tension.
Hi Pete
best thing mate is 2 go 2 a garage and get a print off on that vehicle which is on autodata and that will explain everything you need to know and do mate:)
