found and copyed and updated this from a early post hope it helps!
What a simple job remove three star screws one inside arch two underside front outer corners at bottom edge on both sides.left wheels on and didnt need to jack up. This allows you to push plastic inner arch protector out of way. One 10mm bolt in about 2pm position as you look at wing points straight up holds bumper to the wing.Three large(size of two pence piece) flat quarter turn screws underneath front edge (dont undo just quarter turn and pull down on plastic they should pop out) open bonnet and center panel with second bonnet release on pop up all plastic rivets 5/6 in total lift out of way (Cable still attached can be taken off) Would suggest helper bumper should now pull forward and come off also a bit of masking tape along the wing/bumper joint to stop scratching Also the fog bulb in mine was a H3 55w halfords/fiat and here told me it was a H1 55w such is life
__________________
