Technical ulysse 2.0jtd 2001 smokes from cold start wont rev beyond 2500
ragasteve
hi, i have a 2001 ulysse 2.0jtd that has a couple of problems, the symptoms are:-
the car starts easily but smokes when started from cold( clouds of greyish smoke when reved, ok when ticking over) the smoke clears after a short drive (half a mile or so), it will not rev above 2500rpm in any gear or when stationary, also cuts out when slowing for islands etc or if held at full throttle for any period, the engine continues to run for a few seconds after turning ignition off. I have pluged in fault code reader and it shows the following codes:- p0230, p0115, p0380. p0230 is stored 3 times, the other 2 codes are only stored once. There is no loss of oil or water and the cooling system does not over pressurise. Any help or suggestions would be very much appreciated.
I am new to this forum and take this opportunity to say hello to you all.
Steve
Hi again, just solved the cutting out and problem with not reving, fuse number 10 in the glovebox fuse box was blown, replaced it and hey presto, the engine now revs as it should! just the smoke problem to sort now, it smokes a lot until it is warm (90 degrees warm) and black smoke on acceleration.
spoketoo soon, 20 minutes later and it is back to the way it was!! cheched fuse 10 again and it is ok. Frustrating!
