Down the road from me, bidding on them, hopefully cheap enough with at least two good tyres I hope will help Fizzle through the MOT and clean up later for winter tyres
I may be wrong but they look like cinq steelies to me ?
They are 13's
the other numbers are slightly different,
I think you'll find the mot tester will want the 'other numbers' to match too John, you may get away with it if the pair on each axle at least match.![]()
As long as each axle has the same sized pair on it'll be fine
And make sure you tell your insurer. Non standard or non matching sizes on the two axles will likely be used by them to turn down any claim, so best they are advised (should be no premium hike).
2 tyres are nearly new so they will be fitted on the back axle to replace the cracked ones once they've had a quick going over with the wire brush and kurust. Fancy having some white steelies at some point, anyone got some spare dust caps for the middle bit that sticks through the wheel (my tech knowledge needs to learn the word for that!) ?
