stocky Stocky Parked in the garage Joined Sep 15, 2012 Messages 287 Points 162 Location Newcastle Jun 27, 2013 #1 My 500 is fitted with 145/70R12 69T radial tyres can anyone advise me what air pressure I should run them at please?
jjacob Member Joined Oct 2, 2012 Messages 452 Points 127 Location Franklin, Tennessee USA Jul 3, 2013 #2 I would add 3 psi to the factory recommended pressures for the 125 tyres. John
OP OP stocky Stocky Parked in the garage Joined Sep 15, 2012 Messages 287 Points 162 Location Newcastle Jul 3, 2013 #3 What pressure is that please?
jjacob Member Joined Oct 2, 2012 Messages 452 Points 127 Location Franklin, Tennessee USA Jul 3, 2013 #4 Factory recommended inflation pressure for radial tyres in the 125r12 size were: Front - 16 psi (1.1 kg/cm2) Rear - 23 psi (1.6 kg/cm2) You should run these pressures or try about 3 psi higher. John
Bambino Shed Troglodyte Parked in the garage Uploaded 5 resources/downloads Joined Aug 3, 2009 Messages 1,501 Points 365 Location Sunshine Coast, Australia Jul 3, 2013 #5 My car is also fitted with 145R12s and the tyre fitter suggested pressures of 20psi (front) and 25psi (rear). With these pressures the car isn't too 'bouncy' and the tyre tread seems to be wearing evenly. Chris
