Technical  Tyre pressure warning light
cfp37
Can anyone help?
Keep getting a warning light to check the tyre pressure of front LHS tyre.
I’ve check all the tyres & pressure is fine. How do I get rid of the warning?
Thanks!
Can anyone help?
Thanks!
I had this shortly after a new set of Michelin Cross Climates were fitted. Cursing the lack of 'tyre pressure reset' option on the end of the stalk, I appealed on here and to my embarrassment was reminded of the TPS reset button in the cluster by the Menu button on the RH of your ignition lock. (I can't see any of the buttons in normal driving position so although I may have seen it when I first got the got the car I'd forgotten what was there and must have thought it was the usual array of buttons as in previous Qubos.)
When you're stationary just press and hold the button or press to activate then press/hold and the dash display will acknowledge your action and away goes the annoying warning light.
HTH
R-V-M
